112A/B Hot Shot Empty Weight
jukelemon
Jason Lockwood
Louisville, KY
112B Hot Shot
N377SB
Hi all.
Can you all with 112 Hot Shots let me know your current empty weights?
Thanks so much.
Jason
Re: 112A/B Hot Shot Empty Weight
On serial number 161 I have 1850.38 at an arm of 103.98.
N1182J ser NO 155 1946 EW 102.87"
Ken,
What is on your equipment list? You are slightly heavier than my 1977 114 SN14220. It had a scale weight of 1938.
I'm pretty close to Ken ... 11J is 1,912 @ 104.80.
The airplane was weighed '85 and tipped the scales at 1,846 lbs. The large majority of it's weight gain were three modifications ... SB-112-70A, 71C, and 72A account for 23 lbs, moving to the 3-Blade Propeller added 17 lbs, and the Hot Shot added another 26 lbs. All the other puts and takes have pretty much zero'd out.
Thanks all. I appreciate the info.
Jason
tried to pm you back but would not work.
My cell is 229 407-0200.
Pat,
I am very nose heavy, Sven fixed the cowling where it will never need working again. and of course 82J has everything possible on it.
Sven did many good things to that plane. He posted many of those things on the web board.
We miss him.
You are lucky to have his plane.
Pat,
I seem to recall most of the [extra] weight in 82J was in insulation and replacements of the lines. There was very little factory insulation (sticky aluminum tape, but not much) that year, so that addition was almost exclusively an increase in weight. And the stainless lines weigh roughly 2.5x what the aluminum weighs, and that added up fast.
Pat,
He also replaced the rear plastic panel with a beautifully detailed and padded panel. Must have weighed 15lbs by itself.
He told me once he knew he was putting the pounds onto the plane but he didn't care - mostly flew by himself.
As opposed to Robin Miley who took every nut and bolt out he could. I believe he even cut down the steps to reduce weight and drag.
What happened to Robin's plane? N1390J.
Just sitting in his hanger. I think the registration is expired. He has chronic medical issues, so will probably never fly it again.
