CAVUCO
Deuvall
Utica/Rome,NY
- 1974
- 112 Hot Shot
- formerly N973TS
- 130
Hey Carl, Just watched the Bonanza Society webinar on Turbo Normalized operations. Here. I believe they are all automatic wastegates. They use the TIT to determine LOP peak and always use WOT and never lean on the climb. Not withstanding the POH, with all of your experience with these TN airplanes, can you run through how you setup for takeoff, cruise, descents and landing operations using manually controlled operations. Just looking for your normal procedure, MP, RPM settings, TIT temps (what are you looking for or watching out for, etc). Any difference between 112 and 114 hotshots would be appreciated. What kind of numbers do you see at 10K, 15K, 17K? Do you use the TIT at all for leaning, etc?
