Gear Checkvalve
Re: Gear Checkvalve
Jim:
Put me down for one. I keep in touch about the early Commander mod kit, as that progresses.
Don
Re: Gear Checkvalve
OK, let's go for a 25 pc order. That will save everyone another $20.
But, quickly please, I need to get this order placed.
So: $250 if you order now, else $550 later. $20 back if we reach 25.
Do you require prepayment and let us all know and not sure based on your post or a deposit etc ?
Re: Gear Checkvalve
A bit of clarification. You reference the 112's but not the 114 as much. I thought mine already had the pressure switch. Or does it?
If it doesn't put me down for one. It was asked earlier but not answered. If there is a kit how much will the kit be?
Re: Gear Checkvalve
Jim,
Alright I'm in for the check valve, but like Frank I was wondering if you could provide a bit more info on the "kit". I have an early model 112 (s/n 144) so I am interested in your mod to help us get a bit more reliability zone for gear operation.
Regards - Clark
Re: Gear Checkvalve
Believe this is the underseat checkvalve. It is not a pressure switch.
Re: Gear Checkvalve
Thanks - as I think I had pressure switch on the brain for some reason. Is the check valve mainly for the 112's and/or does the 114 already have one?
Re: Gear Checkvalve
If you read Jim's original post, at the top of this series of posts (which I just did to reconfirm for myself), this is the "pilot check valve" under the rear seat that is already used in your 114. However, if you want a spare to have on hand then this is your opportunity to do so.
Re: Gear Checkvalve
Has anyone needed to replace and existing check valve? Wondering the likeliness of need in deciding whether to keep a spare on hand.
All I did was replace "o" rings when a leak was detected.
Re: Gear Checkvalve
Confirming the subject here is the "piloted" gear down checkvalve, located under the rear seat that maintains hydraulic pressure on the extended gear.
112's up thru 380:
Did not have hydraulic locking of the gear, and thus. no valve.
This valve may be added, in combination with a down pressure switch, or not.
112's 381+ and all 112B, 112TC, 112TCA:
Had 7116-1 valves, parts no longer available.
May be superseded with the 7116-2.
114, 114B, and 114TC:
Had 7116-2 valves (in theory). We find some have 7116-1.
We have a repair kit available for the 7116-2 valves, $125.
Some valve malfunctions can be resolved with ring service, but the primary checking function is via a "trapped" seal that is not field replaceable.
The witching hour seems to have arrived on these valves. Calls are increasing.
For those 112 s/n 1 thru 380 owners interested in superseding to add the hydraulic locking feature, I will structure two kits: check only, and check/pressure.
If I do the chassis and tubing work, the labor will only be a few hours in the field. Kit price would depend on size of the build run, probably not less than $750
and not more than $1500, discounted if you already bought the valve.
For those ordering valves now, Martine is collecting the funds from you as you subscribe.
Re: Gear Checkvalve
Add me to the list for one.
Thanks
Re: Gear Checkvalve
Is that price for the check only kit or the check/pressure kit?
Re: Gear Checkvalve
I did replace my cartridge a year or so after I acquired the bird some 14 years ago. Has been fine ever since. Was OEM valve if logbooks were accurate.
Re: Gear Checkvalve
I am interested in one (check valve) that is...
Re: Gear Checkvalve
Hi Jim,
Please add me for one, also... Been out of town and just caught up with this tread.
Thanks, Alan
Re: Gear Checkvalve
Will the valve work on a 1978 114 if so I'm in for one.
Re: Gear Checkvalve
Please put me down for one.
Re: Gear Checkvalve
Thanks for joining the checkvalve order. I placed the order this morning, covering all requests through this posting.
This thread will continue to run, and may justify a subsequent order at some future time.
Re: Gear Checkvalve
My pretty new check valve just arrived. Thanks, Jim.
Now, my bird is 37 years old with more than 4,000 hours. Do I just put this valve in the hangar spare parts department, put it in the bin in the back of the plane, change it out at annual as a preventative ... or change it right now?
Interested in any opinion on that.
Re: Gear Checkvalve
Scott, what are you going to do with the valve?
