Re: Gear Checkvalve
Confirming the subject here is the "piloted" gear down checkvalve, located under the rear seat that maintains hydraulic pressure on the extended gear.
112's up thru 380:
Did not have hydraulic locking of the gear, and thus. no valve.
This valve may be added, in combination with a down pressure switch, or not.
112's 381+ and all 112B, 112TC, 112TCA:
Had 7116-1 valves, parts no longer available.
May be superseded with the 7116-2.
114, 114B, and 114TC:
Had 7116-2 valves (in theory). We find some have 7116-1.
We have a repair kit available for the 7116-2 valves, $125.
Some valve malfunctions can be resolved with ring service, but the primary checking function is via a "trapped" seal that is not field replaceable.
The witching hour seems to have arrived on these valves. Calls are increasing.
For those 112 s/n 1 thru 380 owners interested in superseding to add the hydraulic locking feature, I will structure two kits: check only, and check/pressure.
If I do the chassis and tubing work, the labor will only be a few hours in the field. Kit price would depend on size of the build run, probably not less than $750
and not more than $1500, discounted if you already bought the valve.
For those ordering valves now, Martine is collecting the funds from you as you subscribe.
