Planecents
Craig
Cantrell
Cameron, TX
- 1976
- 114 Hot Shot
- N4771W
- 101
Re: Gear Checkvalve
Hi Michael, did you completely flush the hydraulic system by looping all 3 gear actuator lines and dumping e-valve so fluid will flush thru entire system? Pumping fresh fluid from the pressure side and back thru the return at the pump before connecting the new one is essential to get all the burnt/contaminated fluid out. I can't stress how important this is.
We have the plane on jacks now and will see if it sags overnight. Again, the last time we put the gear up it has become rock solid. This reflects what it is doing on test flights - perfect for a bit and then the transition light. During the past weeks we have capped off each actuator and they were golden.
A new power pack was installed a few weeks ago and now we are considering contaminants that come and go that may cause a seal issue. Just an inconsistent situation. The gear worked great for 8 years but the last year has been difficult. Thanks again for this input.
