Sherman
Columbia MD & Goldvein VA
- 1978
- 112TCA
- N112HT
- 13254
Re: The Unexpected Drop of MP at 12K Ft
Alex-Glad you were 'calculating' and it worked out fine. We have talked these cables 'to entity' and as we all have shared-the cables, the flexible ends, the rod ends, the adjustments are 'pretty critical' for dependable and safe control - - as well as our own 'Mental Security'. I just changed mine last fall as the flex joint was a bit loose -even though Beechhurst cable was 2 yrs. Once off was not really a problem, so have 2 spares now.
also on our T0-360s- watch the carb mixture SEAL behind the carb lever. Seasonal Temp changes can cause air leaks after a few years. And examine that mixture bracket while you replace the waste gate cable. Bracket can Crack at the 90 deg turbo mounts. Wrote it up ladt fall/Annual. Doesn't always show in cutoff position. As critical as wastegatemps cable. Please do post pic of where cable broke.
