Safety - SOP - Maneuvering speeds
Hmmm...do you have to upgrade to Pro 1000 to get an HSI? I've been reading up on it and all it says is the E5 has a DG...
Mike
That's my understanding Mike. With the E5 you get a DG but a software upgrade will make it into a Max.
However the way they implement the CDI in the instrument is very interesting - some videos on the Aspen site showing the operation. I'm replacing a very tired vac ADI & DG, so this option was very attractive compared to an overhaul of those components. Plus I don't need to purchase a CDI for the new Garmin GNX 375.
In my case I've never had an HSI so I wouldn't miss it. But if down the line they were to wave an attractive software upgrade offer at me, I could be tempted.
My install is scheduled for next month and I'll be sure to get some pictures including in-flight.
Mike
Hi.
The E5 is DG only.
HSI starts at the PRO.
Yeah, I'm kind of hesitant to give up my HSI. Out of my 4,000+ hours, I've only got a few flying a DG and none of that was in IMC. I've got till my annual in April to make a call...I'm going to have to think this one through. I REALLY like the look of the Aspen though...
Mike
Mike
why not leave your HSI in ?
Then later - when you do upgrade - you then give it up.
Problem with the G5 is is that - yes its a lower cost point. But then it starts locking you into limited functionality with no clear roadmap to more.
Any improvements that Garmin would make to G5 - they have to figure out how not to cannibalize the G500 market. So it will remain fairly limited.
With the Aspen, you can invest into the features you want - it has a clear roadmap. And is competing with the G5 and the G500 platform on both ends.
i am not knocking the G5 - it does what its meant to do well. But thats all it will do. I will happily install one on the co-pilot side for my daughter to use in a couple of yrs. -
2 x G5s >> exceeds an Aspen E5 -(HSI, etc.)
2 x G5s << don't add up to 1 x Aspen pro.
1 x G500 is kinda equal ~= to 2 x Aspen Pros. (at a similar price point).
2 x Aspen Pros just run away from the G500 because of legacy Autopilot support. Garmin will never certify the GFC for our birds and isn't willing to play nice with non-GFC autopilots.
I hadn't thought about that option. 2 x G5 isn't an option since the G5 in ADI mode will not drive my AP. At this point, my options are a KI-300 ADI and G5 HSI or an Aspen E5-to-Pro (analog HSI ditched)-to-Max (if I decided to go that far). I'll have to take a close look at my panel this weekend to see the space requirement for an Aspen + my King HSI.
Mike
If you publish a picture of your panel - we can comment on the least disruptive option(s)
my panel has been a 20 yr journey and never cut - as i never reached some desired end-state (i am close now) but some minor tweaks left.
Here's some new instrumentation coming down the certification pike pilots are talking about at my field. No panel surgery involved. Nice G5 look-alike and AI which interfaces to legacy S-TEC autopilots....same people Glenn talks about for tailbeacon ADSB...many pardons if this was mentioned already.
https://uavionix.com/products/av-30/
jay - this is a nice contender for me when i rip out the AI when i get the Aspen Max.
At $1600 with more functionality than a G5 - its well placed. STC expected 2020.
It's not an Aspen but i don't see anything that a G5 does that this can't do.
Both that AV-30 and the smaller AV-20 are both neat looking products. Jeff Bethel, the founder of AeroVonics (the company that uAvionix acquired to get these products) was co-founder of Aspen so I'm not too surprised at the functionality and utility.
I'm also intrigued by the AV-20S - quite a bit of functionality in a 2" device for $895. Even has an internal 30-minute battery.
I've been exploring my options in "going glass" but there appear to be few actual options for my KFC-200. I've figured out I either go with a KI-300 ADI with a G5 HSI which should cost $8422 + install or the Aspen option at $12,990 + install (just Pro, not Pro Max). Obviously you get A LOT more for the additional $4K from Aspen but I'm not sure its worth it...
Mike
Update Mike - Aspen just switched the Evolution E5 main display from a basic DG to a HSI. No price change to the unit itself.
My Aspen 2K is doing fine.
My pre-existing vacuum Attitude indicator is now on an accelerated path to failure.
I flew from PA to RDU yesterday. It was dancing the whole way. I wouldn't fly the airplane IMC like this. Stayed VFR the whole way. Was a bumpy ride south of Richmond.
Now considering replacement of the Vac AI once i get back North (spring).
- L3 ESI 500 and SAI 340 are approved candidates.
I have the G5 and I like it but there's a lot to be said about not having to modify the panel. Interesting product!
Interesting...so, let me see if I understand all that's involved to tie this in to my King autopilot...$4,495 for the E5 + $3,075 for the EA100 + $2,480 for the ACU = $10,050 + install. Is that correct?
Mike
Mike
Not sure for your King AP, but with my STEC 30 w/alt I only needed the ACU and cost for that add-on was $1K. So I'm $6K total for Aspen.
I definitely need the EA100 for my attitude tied King Autopilot. ACU currently lists for $2,480.
Mike
