Rear seat installation bolt identification.
TheCommanderSim
Richard Long
G-LITE
I am trying to identify the screw/bolt/fasteners used to attach the rear passenger seats to the fuselage.
I have identified the four fasteners at the front of the seat assembly, but the IPC doesn't show any of the fasteners at the rear of the base frame.
Could anyone advise?
Thank you
That's probably because the two outer bolts Are actually luggage tie downs . I'm sure you could find bolts That would hold The seat In place Without the luggage Loops . I'm attaching a picture that I picked up from an Old Post That might help . image_8919.jpg
Hi Joel,
Yes exactly these bolts. Any idea where they are in the Parts Catalogue or where I can get the part number to trace the size/spec?
Thanks, Joel.
Much appreciated. Now to try and identify the thread spec.
Best
Richard
It is a standard thread but I would have to pull one out to get the actual spec - no where near the plane.
Standard thread - I would think that you can try a couple of sizes. The hole in the frame limits the size bolt that will fit.
If it is any help it is slightly smaller that the hole and the frame and fits snug.
Cross references to this
Wow, Joel you are a wizard. Google came up with very little when I searched. Thanks!
