Circle on the tail
CaptainMorgan
Patrick Morgan
What is the circle on the base of the tail of the airplane? I almost always see it in pictures, but I can not find out what it is there for.
I'm assuming you mean the small black plug - although it's painted on some airplane. It is access to a bolt on an arm that is part of the elevator assembly.
If you're talking about the circle on the front at the bottom - that would be the air intake for the overhead vents. There's a vent above each seat similar to the kind of vents you have in commercial airplanes. Later planes actually have a NACCA scoop on the right side rather than the what we call donut hole in the front
Thanks this is exactly what I was looking for!
If you’re looking to spend some money Captain, and who isn’t that owns a Commander, there’s an aftermarket replacement for this “donut” dorsal fin to a replacement fin which has the intake on the side, aka the NACA scoop as Joel says. It’s very easy to change out. Like everything, it is rumored you pick up a few knots airspeed due to the aerodynamics improvement. Yeah right.
It’s funny, the other day some kid lineman asked me what that hole was for and I told him I thought it was the intake for the APU on the plane.
Well I wouldn't say it's 'very easy' to change out to the NACA scoop. I had about 6 hours of trimming and work to get it to fit correctly. :)
