Turbo Gaskets R&R
jukelemon
Jason Lockwood
Louisville, KY
112B Hot Shot
N377SB
Hi all.
My AP and I are about to do this. Before we reinvent the wheel...any shortcuts in this procedure i.e. what not to do because it is not necessary?
Thanks.
Re: Turbo Gaskets R&R
Anyone?
Make sure that you have new gaskets on hand, Carl should have them. carry spares
Thanks Ken. Yes, I have them
I am a little surprised this is falling on deaf ears :D
So no one changes these at annual/does am Owner Assisted annual??
Don't know about the hotshot but I never touch the turbo gaskets unless I have a reason to disassemble something. They will last the life of the turbo.
Thanks Joel.
That is good to know.
We are talking the intake and exhaust gaskets. Yes?
FYI re: Turbo gaskets; same as Joel
Same as Joel & Vince-only changed when Engine, exhaust components work or Turbo overhaul. However, we recently discussed the Turbo Clamps -tension and construction integrity. Also the clamp (s)/ Bands have a specific tensioning specification(s) and Safety wiring techniques.
These clamps are best left alone unless you have to disassemble the exhaust. On the TC -- we'll have quite a bit of exhaust residue around the joints and you learn to accept "normal". I have no experience with your hotshot exhaust.
If you do take them apart -- heed the Lycoming SB. You don't want to be roasted at altitude.
