New owner N1250J
Actually there are only 2 there now since Dennis arrived recently. The one by the shop is from Sussex and there for maintenance. Good to see you although brief. Hopefully we get together again at Sky Acres in the spring.
Best Rgds.
Joe T
I thought Commanders were a rare breed. Too bad I was departing and not landing....would’ve grabbed a cup of coffee and asked a million questions. Please let Joe and I know if you’re coming to Blairstown again!!
Door stays will probably go in during annual. First order of business is installing a Plane Power alternator to get rid of the pulsating in my headset and getting an engine monitor. I’m open to suggestions but highly considering the EDM-830 with Fuel Flow.
I'd recommend an EI CGR-30P. That could replace the RPM (or Manifold Pressure/Fuel Flow) and provide everything the EDM would and a whole lot more.
That is what I installed. It is certified as primary instrumentation, but I actually kept my old factory gauges. Now I have backup to the CGR-30P and I kind of like the look of those small round dial gauges.
JPI 900 can do all This:
• Pre-Wired Harness for all functions
• New Display SVGA & view angle 85 degrees all around
• Back lit buttons
• RPM Prop
• MAP Manifold Pressure
• % HP Percent of Horse Power
• EGT Exhaust Gas Temp.
• CHT Cylinder Head Temp.
• EGT Normalize mode
• LOP/ROP JPI Exclusive Leaning Mode
• O-T Oil Temperature
• O-P Oil Pressure
• F-P Fuel Pressure (when in POH)
• OAT Outside Air Temp.
• VDC Voltage (1)
• AMP Current amps (2 twins)
• Fuel Flow Transducer FlowScan
• GPH Gallons per Hour GPH
• REQ Required to wp or destination
• USD Fuel used
• H:M Endurance Hours and Minutes
• MPG Miles per Gal
• CLD Shock Cooling on ALL cylinders
• DIFF Difference between EGT’s
• USB Memory stick 1 GB
• Data Recording 800 Hrs every 6 sec.
• EZTrends Graphing Software free
• 3 year Warranty
CGR30P: [TABLE="border: 0, cellpadding: 3, cellspacing: 0"]
[TR]
[TD="width: 200, align: left"]RPM[/TD]
[TD="width: 200, align: left"]Oil Temp[/TD]
[TD="width: 200, align: left"]Oil Press.[/TD]
[/TR]
[TR]
[TD="width: 200, align: left"]Manifold Press.[/TD]
[TD="width: 200, align: left"]EGT/CHT Bar Graph[/TD]
[TD="width: 200, align: left"]Fuel Flow[/TD]
[/TR]
[TR]
[TD="width: 200, align: left"]Fuel Press.[/TD]
[TD="width: 200, align: left"]Fuel Level[/TD]
[TD="width: 200, align: left"]Flight Timer[/TD]
[/TR]
[TR]
[TD="width: 200, align: left"]Tach Time[/TD]
[TD="width: 200, align: left"]Local Time[/TD]
[TD="width: 200, align: left"]Zulu Time[/TD]
[/TR]
[TR]
[TD="width: 200, align: left"]Annuciators[/TD]
[TD="width: 200, align: left"]Data Recorder[/TD]
[TD="width: 200, align: left"]USB Port[/TD]
[/TR]
[TR]
[TD="width: 200, align: left"]Caution Lights[/TD]
[TD="width: 200, align: left"]Fuel Remaining[/TD]
[TD="width: 200, align: left"]Fuel Used[/TD]
[/TR]
[TR]
[TD="width: 200, align: left"]OAT[/TD]
[TD="width: 200, align: left"]T.I.T.[/TD]
[TD="width: 200, align: left"]Low Fuel Alarm[/TD]
[/TR]
[TR]
[TD="width: 200, align: left"]Volts[/TD]
[TD="width: 200, align: left"]AMPS[/TD]
[TD="width: 200, align: left"]and more!![/TD]
[/TR]
[/TABLE]
