New York, NY
- 1976
- 112TC
- N976MA
- 13043
Frank, seriously - no offense taken! Just a thought that crossed my mind as I'm thinking about the project/problem/solution. Please share your thoughts about why "it's insane" - the more educated I am the better I can come up with the best resolution. I've got a replacement 35-amp pullable in hand. I've also got plenty of space in my panel to put it - where all of the factory gauges were. I could install the pullable c/b in that location and wire it up - I've got power from the main buss to that location already.... Another thought...
Thanks.....
You're trying to solve 2 problems here .
1) How to protect the electrical circuit, motor, other components etc due to a short / overload etc
2) Disable motor in case of logic failure due to bad microswitch, etc
Putting a pullable circuit breaker solves 1) and 2)
Putting a switch there only solves for 2).
now if i misunderstood your post - you want to add in a switch in addition to the regular CB - why add the complexity ? You *CAN*.
One more thing to check, on more thing that will fail etc ..
