nathanbauder
Nathan
Bauder
- 1976
- 112TC
- C-GIHQ
- 13092
Hello fellow Commander Owners,
Pleased to join this informative community. Getting to know this aircraft has been interesting, having come from a Cessna Owner background (R172K, P210N).
Completed a nice panel upgrade recently.. Finding power settings a bit challenging, with some hesitancy in advancing power through 1400 to 1800 RPM. Had a carb rebuild as a result of a post purchase annual where it was determined carb had some pitting and corrosion making it U/S. Took a lot of effort and luck to find a replacement despite herculean efforts. Discovering now that the TO 360 is quite the particular engine in terms of sensitivity to a number of factors like elevation and temperature (not fond of cold Canada). Hard to get the Carb Temp up but the suggestion of the oil cooler plug found on the site here helped.
So, any thoughts on the power issue? If I play with the mixture, ie lean it to the "M" engine smoothes out somewhat. This occurs at run up and then powering up for the takeoff roll, via holding at 30 inches for spool up. Even then, I seem to still need it leaned out a bit to get the engine to smooth out.
Looking forward to hearing any thoughts and thanks again for all the help so far.
Nathan
Nathan
