? Not sure I follow Rolf.Jason,Jason,Jason, first it’s too cold out,now your airplane is too hot, which is it?
Want to sell that plane? It’s only 7 above up here, I could use a warmer cockpit!
All in fun friend...
Agree...I also have the 112 hot shot. Carl told me there was no reason I couldn’t have 4 shrouds instead of 2. I’m going to do this.
Ok... I see a callout for 4 on my HS manual.
Carl: is there a reason one would not do 4?
Thanks
Thanks Carl.The early original design used 4. I'm not sure if any of these still exist - I haven't ever seen one. The later, improved design, uses just 2. I'd have to see a picture of yours to know which you have.
There are better, and worse ways to plumb them that make a big difference in their performance.
Thanks Carl.
I have 2 now. Can you please explain the better and worse ways?
When I look on the Right side, there is a really steep bend from the cowl intake to the shroud. The SCAT has to really rise quickly to get to the shroud intake.
Thanks
Ah...that explains it.N1182J had the 4 on when Sven bought her down to Georgia. Said that I did not need 4 and the extra would get in the way when working on the plane.
We took them off but unfortunately I did not get any pics.
I have the parts but would have no idea how to fit. I will look at old pics and see if I can find anything.
Life is a barrel of fun.
Thanks Ken.
The 1st pic...
Looks like the heat vents are off i.e. I see the line going up which I assume is going to the T then to both the Defroster gate and the heat vents. But I dont see the heat sent at all.
Did he run one heat shroud for the Defroster and one for the heat?
On a different note...that is a damn clean engine.
Jason,Thanks Ken.
The 1st pic...
Thanks Neal and understood. That makes sense.Jason,
1182J (and 1286J for that matter) is a much earlier Commander than yours. As a result the heater routing is different, so I would suggest that you could not route the SCEET in quite the same manner.
Ken,
It appears there is a typo in your signature. N1182J is a 1974 Commander.
