FAA proposes AD on Piper wing spars
Pat
Guest
Patrick Murphy
Sturgis, MI
N374JW
Wing life limits are coming into play on other aircraft. Quote from AOPA
FAA proposes airworthiness directive on Piper wing spars
The FAA has proposed a new airworthiness directive (AD) requiring the inspection for metal fatigue of main wing spars on numerous Piper PA–28 and PA–32 single-engine airplanes that have reached a certain factored time-in-service level; reporting the inspection results to the FAA; and replacing wing spars that fail the inspection.
The AD—which the FAA noted could be an interim action with further rulemaking possible—would apply to the listed PA–28 and PA–32-series airplanes that have either accumulated 5,000 or more “factored” hours time in service (TIS); have had either main wing spar replaced with a serviceable main wing spar (more than zero hours TIS); or have missing and/or incomplete maintenance records. An aircraft’s applicability status would have to be determined within 30 days of the AD’s effective date. Before further flight, a formula provided in the AD, tied to the number of 100-hour inspections completed, would be used to calculate the number of factored service hours for each main wing spar of an airplane to which the AD applies.
https://www.federalregister.gov/doc...iness-directives-piper-aircraft-inc-airplanes
Re: FAA proposes AD on Piper wing spars
That will put the backlog on the FBO system! Just about every Arrow and most Cherokee's that have seen flightline service will have those hours. Massive impact on maintenance facilities. k
I think in many ways on an average we're very fortunate that our fleet has not be used as a trainer base such as the case with the PA and Cessna birds . .
Quote from the attached article: The school’s fleet of about a half dozen Piper PA-28 aircraft remains grounded, and it’s not clear whether they will ever be flown again.
Also Mike Busch is on that investigation team. Maybe one day we can read his candid assessment.
