Richards
- 1978 580
- Super Commander
- N555LP
- 14405
Anyone want to join a run of cabin door hinges?
We have previously engineered the basic replacement hinge blanks, and have personalized and heat treated a few of the 43722-3 (lower forward). Now comes another owner who needs the lower aft so we are about to run through the process again.
The process involves machining, then heat treating, then machining, plus priming, etc so the bigger lot of hinges we process, the cheaper for everyone. Just thought I would check and see if any of you with worn/bent hinges would like to join a run at this time.
Certification is by included Form 8110-3.
We include the 4th hole in the aft half, the improved design that prevents wind and racking from bending the door half of the hinge, thus the installation is improved.
