Rolf
Ringgold
Circle Pines, MN
- 1974
- 112/A
- N1215J
- 215
I taxied away from the self serve pumps at KMKY, 1200 miles from home and noticed my alternator wasn’t charging!
On a Saturday no less, no mechanic around until Monday! Yikes! Now what? I’ve never had this happen in 7 years of ownership.
Before I shut it down I increased the RPM’s and watched the alternator output drop to zero. After shut down I had cycled the circuit breaker which apparently reset the alternator. After texting the owner of the local maintenance shop he suggested I speak with Andreas at his hangar. Andreas suggested that I start the plane and shut down the alternator side of the master switch which hopefully will reset the alternator. If not, well then more maintenance would be required on Monday. So much for leaving when the weather looks good!
We’ll, it appears that my cycling the circuit breaker did the trick, because when I restarted the engine, it was charging. We recycled the alt side of the master anyway. So we’re back on track to leave Sunday morning, what a relief!
Someone is testing my patience.
I’ve owned a couple of cars that required the rpm’s to get up into the 1400 range before the alternator would activate, but never had an airplane do this.
Live and learn!
Live and learn!
