rcastillo
San José, Costa Rica
- 1976
- 114
- TI-COS
- 14128
Hi:
Today I was flying back from MRMR, a private turf runway in the north pacific coast of Guanacaste, to our home base ar MRPV; the whole preflight was perfect, no issues at all, the engine check and all.
I have the habit, good or bad habit but I have it, of leaning out as part of my magneto check, so I am sure the mixture control was working fine up until there, and again, all preflight and pre take off checklists perfectly ok; we started the take off using the soft fied technique, this time with 15° flaps to try what some thread was commenting here a few days ago, that setting worked perfectly, we were off the ground quickly and started ascending at about 1000 ft per minute.
This was just the second flight after we installed a JPI 450 so I am still getting familiar with it, after passing the after take off checklist, I pulled the mixture a little to 1300° F which was showing about 19 gal per hour on the JPI-450, (at 3000 ft indicated, we are normally passing 5,500 ft densitute altitude) I continued climbing and about 5,000 ft I noticed the EGT close to 1,500; of course, that called my attention, I was sure I had not pulled the mixture that much, the original fuel flow indicator was indicating just a little over 10 gal per hour and the JPI 450 was indicating a little over 12, so I enrichened the mixture but all I got was the JPI 450 to show 13.6 gal per hour and the EGT just to settle around 1480, our engine peaks about 1525. I checked the fuel pressure and it was well inside the green arc with about some 22 inches, cylinder temp was just over 400° F which was a little on the high side but no to get scared about it, oil temp and pressure were also OK; so I decided to continue and monitor the situation.
We continued climbing but I decided to settle at 7,500 since it was already a good enough altitude and the temps were just ok so I was trying to keep them under control by gaining some airspeed to help the cooling and to not to make the engine suffer with the high EGT during climb and risk raising the cylinder head temp even further; I decided not to touch too much the engine controls since the low fuel flow, which was now just about 12 GPH, and EGT were obvious indications of something not being perfect; appart from that, everything else was just perfect; now it was time to descend and I didn´t want to cut back too much on power since I was affraid that I would be inviting the unwanted silence of a dead engine, so I kept the Manifold pressure to 20 inches during the whole descent, which where I keep it anyway, but on final approach I kept it just at 18 inches until we were above the numbers and kept a little power until touch down, when I retarded to minimum, the prop just stopped; by then, we were still rolling, so I made the first exit without power, I tried to restart the engine, but it just didn´t; so we had to push it to the hangar, which thank goodness was very close to the intersection we stopped.
I don´t think this event has to do with the installation of the JPI 450 but rather with a mixture control adjustment that was done while we were testing the new 450, we felt the mixture was too rich and then the mechanic adjusted it. I guess something got loose from that adjustment. On the outbound leg we flew on Friday, everything worked fine.
I had with me my wife, our 17 year old son and our 7 year old daughter, all them took this very calmedly and were confident we made the right decisions; my son was flying copilot and we were commenting the abnormalities during the flight, so they were all aware of what was going on. Ah...we modified the route a little bit just be closer to potential landing sites.
Do you guys agree with my mixture control theory or do you suspect something else?
Thanks and best regards,
