New Member with Lots of Questions!
AGF CZBA
Andrew Fitzpatrick
Hello everyone, I've just joined up and this is my first post. I want to thank you all for providing this site, I have already leaned quite a lot and used the FAQ document that is available. But of course many more questions and I'd be grateful for your collective wisdom.
First a little about me to put the questions that follow in context. I have a little over 200 hours, about 100 in Cherokees/Warriors 30 years ago (long story) and about 100 in DA-20s in the last year. I passed my PPL flight test and written in December 2023 and have about 5 hours since in a DA 40. I'm now looking to buy my first airplane. In terms of mission, I'd like to complete an IFR in the next couple of years, 100-300 mile weekends with my family of three (all together we weigh 400lbs) and once I get my nerve up 1 or 2 1000 plus nm trips a year (I'm in Canada, it's big!). And lots of hamburgers. Lots and lots of hamburgers.
After determining that fixed-gear Piper prices have become crazy and Mooneys are incompatible with my knees, my list became Arrows and Commanders. But really I always leaned Commander for no better reason than it looks so good. And a sensible number of doors. I've now found a very nice 112TCA at my preferred airport, 3000 TTAF, 300 SMOH. Initial impressions are favourable and of course any offer would be subject to PPI. With that, my questions, most of which revolve around the turbo:
1) It's a turbo. All other things being equal I thought I preferred a 112A or B. It's not so much the extra fuel burn, you can go slow and burn less if you want, or the increased overhaul cost, I'm more concerned about the extra engine management given my limited experience. I think I will already have lots to learn with the prop and gear. It has a G2 Insight graphic engine monitor. Am I going to go off the left side of the runway while watching the MP on takeoff? Am I going to cook the turbo when out of instinct I go all levers full forward on a go around? Or am I overthinking and its no big deal, just a couple of numbers to monitor and a nice digital display that's up in my line of site to make it easy?
2) What does the extra management and cost get me? I know more altitudes are available, hopefully I will grow into using them. I understand that it is not turbo normalized, so not producing 210hp at altitude. Producing more than the non-turbo 112, but not maintaining rated power as you climb. Is this correct? What does this mean for hot and high runway/climb performance? I'm not in the mountains but it is 35 degrees celsius (95f) and quite humid quite often and depending on the wind I have a 2400 ft runway at home base. Is the turbo going to help here? I expect it's better than the straight 112, but still no rocket ship.
3) More engine questions. I see oil being topped up regularly in the log. I expect it to burn some oil, most engines do. What would be considered a normal amount to add for every 10 hours? Do these engines typically make TBO? There are not a lot of these TO-360s in the field, any issues with support, parts, finding someone familiar with the engine to do an overhaul?
4) ADs. Canada and the US treated the 90-04-07 wing spar AD a little differently, with Canada only requiring the fix if a crack was found (I learned this from your site, thank you). A log review indicates the spar mod kit has been done so this is a relief. However, the elevator spars are being borescoped every annual. If cracks are found, how much is the fix going to cost? Are parts easily available? I think Aerodyne sells the kit?
5) Speaking of parts, how helpful is the current incarnation of Commander Aircraft? I know they are in business and have a list of parts available on their website.
6) Getting ahead of myself with this one, but how about the VG kit? I think it would be my first mod. I think you lower stall speed by 4 knots? Seems like a good deal for the $3-$4k CAD installed. I know it also increases rudder authority. Any other benefits? Takeoff roll, climb? Confidence for low-time pilot managing a turbo?
That's a long list, and many thanks to anyone who takes the time to respond to offer the benefit of their experience. Do not take my long list as a sign of lack of enthusiasm, I really like the airplane and the current owner who seems very diligent in his maintenance and record keeping. Just trying to be thorough and benefit from the wisdom of the Commander community.
Thank you!
Welcome, I flew the Al-Can highway back in the 90’s, great trip. I also did 2 fishing trips & a relative visit to Canada.
Pay attention to useful load, most 112’s aren’t know to be heavy haulers. The load available should be from the high 800’s to around 900 lbs.
The 112 isn’t a good choice for any shorter field ops, well, Winter temps & solo could be ok.
Yes, the Commander does usually get more attention on the ramp, kinda like taking that pristine 68 Mustang to the drive-in.
A 400 lb family isn’t bad though, often not all want to go at one time, maybe less so with a younger child. Back in the day I flew us all from WI to Disney in FL, April. The 4 of us weighed 555 lbs, flew a Warrior. Of course I light-loaded the fuel, used a ‘fuel straw’.
Welcome- You're looking at one great airplane! I have owned mine for 20 plus years. I noticed you are in the public forums which means you have joined as a member, yet. There is a huge amount of information available in the member section and I would suggest that it would be more than worth your while if you're looking at commanders to spend the $75 and join and get full access. There are a lot of things that won't be responded to in the public area but will be responded to in the members area.
Thank you Joel. I have signed up as a member and thought I was in the member only forum. Lots to learn, even about the forums.
You will get there- it's not that hard. Hopefully you've been perusing the members section. There's a huge amount of information to be had there. Since you are a member, it is always best to post on the members side as people are reluctant to respond on the public side which can be accessed from anyone on the web.
Needless to say, the public side is fine for introductions, but if you have any specific questions, go to the forums and you'll notice that all of the ones on top are members only until you get about halfway down the page and then you'll see all the public forums listed.
AGF CZBA I assume you are out of/around CZBA. We own a 112 out of YKF and I work in Burlington so if you want to have a call or coffee to discuss Commanders just PM me.
Welcome! Regarding #4 elevator spars, while the borescope AMOC we developed is a pretty easy annual check, Sterling Aviation sells a complete kit that is a terminating action for the AD. I'd check with Paul Sterling to see if there are any Canada-specific issues. Sterling Aviation Technologies – Manufacturers of replacement parts and modifications for the Piper Tomahawk and Commander 112/114
And regarding CAC, don't expect much from them. They do have some parts that they can legally sell. Fortunately, Rockwell used pretty standard off the shelf parts where they could in these aircraft. And for some of the more difficult to find pieces, we have worked well with salvage yards. And of course, the nice thing about a metal aircraft is that it lends itself to maintenance and repair that thousands of shops can perform.
I have owned and maintained a Commander for 19 years, And I still have a Lots of Questions.
If it were not for the Commander Owners Group I would be broke by now. This group was one of the main reasons I chose Commander.
Welcome .... Did you pull the trigger and send in an Offer to Purchase?
Hey. Another 20+ year 112TC owner.
I stepped into mine with 300 Hours total time. About 20-30 hours in Turbos (Turbo Saratoga, T210 , Turbo-arrow).
All other time was in Warriors, Archers, C172. I also have 1 hour each in a C152, DA40. These were kites compared to the above turbo birds.
I initially looked at a 112A but eventually decided that a 112TC will do better ( i stumbled into one).
Zero regrets.
Pros : It will produce the rated 210 HP - so high DA take-offs are a non-issue. It will easily carry its max gross (and then some with a ferry permit). Summer Ops/winter ops - no issues. Fly it some modified procedures (deviating from the POH) found on this forum.
e.g. Rotate w/ 10 degree flaps like a 727 at 72 Knots vs POH (no flaps and 65 Kts). Gives you a positive rotation, climb rate and controllability (no VGs required).
Cons :
The aircraft does require a good pre-buy ( so do others but the engine requires a close look).
Yes - there is engine management involved - fly it like a jet. There is turbo spool-up on take-off but 2-3 take-offs with a seasoned instructor and you shouldn't have any issues.
Go-arounds - you go to TOGA power - not max wide-open throttle.
Parts - some of the engine components like cylinders are more expensive - so treat you engine well. However - everything is available.
Your Oil burn question : 1 quart every 4 hours or greater is a healthy engine. Its doing its job. 1 quart every hour is bad.
