marcelo67
Pittstown, NJ
- 1973
- 112/A
- N1075J
- 75
I just wanted to share this with you all.
Since my CFI drilled into me from day one that "Side steeping" after departure is good practice, I never stopped doing it. Today at 47N after departing 25 and around 600 agl I turned 270. At 720 agl 75J decided to shake and then stop! I can tell you this for sure, Commanders are not bad gliders too. Because I was 20 degrees off center line it made for the easiest turn and glide back to runway 7. I was even high for that approach.
I am a firm believer that side stepping does work when you need it the most.....real close to the ground.
I can also give much thanks to the BIG guy.
Now it's time for a new power plant.
Cheers
Marcelo.
Cheers
Marcelo.
